1989 Trail Boss reverse eliminator
Old Oct 25, 2018 | 02:16 PM
Serenity's Avatar
Default 1989 Trail Boss reverse eliminator
Hey I just realized I posted in introduction page and was not supposed to. I read about black wire for reverse limiter switch that can be disconnected if starting is an issue. Can some one tell me where said wire is and where connection is The switch has two wires either of wehich is not black My story on this quad is in the introduction thread
Old Oct 25, 2018 | 04:26 PM
94harley's Avatar
The reverse limiter box is where the black wire is located you need to remove. Not the switch on the handle bars. The switch itself is under the front headlight cover(tucked in behind the oil tank). There are 2 black boxes up there that are bolted together to the frame. The limiter box has a green, yellow/red, white and black wire. Remove the black wire on that box(the other box is the voltage regulator) and it will no longer function. Disclaimer, if you do this and run it in reverse, it will have the capability to go full rpm and can be dangerous.
Pic robbed from the internet-pending, not sure what happened.
Last edited by 94harley; Oct 25, 2018 at 04:27 PM. Reason: Pic didn't show up for some reason
Old Oct 25, 2018 | 09:02 PM
Serenity's Avatar
Thanks Harley
Zeke123
Nov 3, 2015 05:04 PM
saint650
Apr 29, 2012 01:00 PM
donmullins
Sep 13, 2010 07:30 PM
beninlou
Dec 29, 2009 04:53 AM
PolarisATV89
Aug 9, 2007 03:44 PM
