Rear caliper affecting foot brake
Old Nov 13, 2018 | 01:07 PM
talshiar's Avatar
Default Rear caliper affecting foot brake
Background: I have a 2007 Sportsman 800 EFI. It had the classic issue of the foot brake not working. There was enough corrosion on the rear caliper I decided to replace the rear caliper, foot piston, line, and reservoir. I fully bled all the brakes, it was time.
Issue: When using the using the brake handle there is no resistance, you pump it a few times and then the fluid leaks out the foot brake reservoir. This appears to either be:
1) Defective rear caliper issue, there is a leak between the pistons causing the fluid to mix and the hand brake to move pressure into the foot brake
2) Defective foot brake piston, the seal on the piston is actually supposed to keep back pressure from the main brake from pushing into the reservoir.
I would appreciate some expertise, is the rear caliper piston supposed to allow mixing of both the main and foot brake or is there a broken seal in the new part I bought?
Old Nov 14, 2018 | 09:42 AM
94harley's Avatar
That system uses 1 piston, with 2 seals on it that separate the front from the rear(hand and foot) brake. One of the seals is torn or cut is my guess. If OEM caliper get seal kit 2201872 and tear it apart. If aftermarket caliper, not sure if they are rebuildable. Its not just a typical o-ring in the caliper piston. They are "Square cut o-rings" so my guess is auto parts store will not have anything close enough to fix.
Redfiretaco
Oct 3, 2014 08:44 AM
teamrev
Sep 18, 2010 07:54 PM
toddmh
Sep 30, 2008 09:19 PM
motox26
Sep 2, 2005 08:02 PM
HooPharted
Jul 3, 2005 07:17 PM
