2000 Polaris sportsman 500 charging question
When it is charging all is good but then it drops down to battery voltage unless the lights are on or fan is running. With them running the voltage drops down to around low 11's or high 10s. You can hear the relay click then it's stops charging and it will click again and start charging.. I have also replaced the relay . Other stator and regulator was doing same thing. That's the reason I replaced them
