2000 polaris 500 magnum over charging?
Hello I have a 2000 Polaris 500 magnum that is constantly burning out all the headlights and sometimes draining battery after sitting a couple days , while not running it has 12.5 @ the battery, But while running I checked the charging system @ the battery & my tester only goes up to 16 & it burries the needle way past 16 @ an idle, could someone please help me out ?
Not 100% sure but sounds like voltage regulator is bad usually located on inside front grill some mounted to alluminium angle L shaped piece # 33 on partzilla engine taillight illustration do a search with part # might be able to get a cheaper one online ?if to pricey
Keep us posted
Keep us posted
