Tring to get a Xporer 400 to wheelie...
After I put on my performance stuff, wheelies are now a way of life. My good riding buddy has a '98 Xplorer 400 that has a hard time getting and front tires in the air.
It is not laking power, it has plenty of get-up-go but can't wheelie. He has a K&N filter, Boyesen Pro Reeds (carbon fiber) and a stock Scrambler primary spring.
This machine goes throught the mud, does farm work, and can beat a Grizzley 600 and Sportsman 500's at an ATV pull! In two years he has put on over 6000 miles. Not bad.
But he wants to be able to pull wheelies, mostly cuz they are fun to do. Will a different spring or a clutch kit make the difference? He has no plans of getting a performance exhaust...but we have thought about putting my stock Scrambler pipe/muffler on it just to see what happens. He also does not want to spend too much money.
Thanks.
'96 Scrambler w/RCR Stage 1 Kit, K&N filter, and Boyesen Power Reeds. Clutch kit soon....
Thanks.
adamnieman is actually asking the question for me. Right now I have a K&N, boysen pro reeds, and I put in the stock spring from his scrambler since he got an rcr kit. Putting a knee to the seat, I can get the wheels about a foot off the ground in High gear. Low gear results in nothing or grass in the undies. I'm probably putting out about 37hp...any suggestions??
'98 Xplorer 400, K&N, boysen pro-reeds, stock scrambler spring
Install the green primary spring.This will make your quad go over backwards in low range.Contact Rick Ritter at RcR racing.Cost is around 25 dollars plus shipping,
Bill Ciliberti
00 Xplorer 400cc 4x4
26 inch Mudrunners
PSI pipe w/Scrambler silencer
RcR airbox mod
KN and Uni filter
Hot Seat clutch kit
Delta V-force reeds/spacer kit
If you want to come in second''FOLLOW ME''
Bill Ciliberti
26 inch Mudrunners
RcR airbox mod
KN and Uni filter
Hot Seat clutch kit
MUDDY4LIFE,
Good call on the spring. He called RCR and ordered it. Should be here next week sometime. Will post the hopefully good results.
Glad your PSI pipe turned out good in the end. Your Xplorer should be pretty damn fast now!
