Polaris four wheeler
Hi I have a 1994 polaris 300 4x4 and I have hi gear it shifts into but no reverse or low. It will sometimes grab reverse for a second but not stay I've tried adjusting the shift rods but no luck also have new ends on the transmission for the rods any help would be appreciated
I'm new to the forum, but surprised this post hasn't gotten any replies. I have the same wheeler, so I hope you get answers to this.
I have a couple cents to offer. But you probably already tried and by Now have already figured it out.... adjust your shift rods by loosening the locking nuts, then turning the linkage rods one direction till a resistance is felt. Then counting the turns, turn the rod back the other direction till resistance is felt again. Then turn the rod back the other way HALF of the number of turns you counted. Just a little off can make a huge difference of it's shifting. But, that procedure is what I read from an expert, and it works.
I hope I have helped, at least helped another forum browser!
Jlait1982
Jul 21, 2017 09:41 AM
