help... leaking oil
Old Nov 28, 1999 | 12:37 PM
DaBoss's Avatar
I have a new 2000 Trailboss, yesterday after riding in lots of mud and snow (northern minnesota) I noticed oil in the trailer. The hose that goes to the oil cooler was spewing oil all over when it is running... I haven't got the mud off to check it yet. Could there be some bigger problem causing this or just a loose fitting/broken hose ??
Polaris SHOULD cover this right ???
Old Nov 28, 1999 | 01:57 PM
Kagey's Avatar
You should have no problems with them covering it but if its a simple cut hose you may prefer to change it yourself to save time and the hassle of having to carry it to the dealer to fix it, no doubt if it is a hose problem it will be very cheap to fix it yourself. Check the fittings on the oil Tank and make sure they are not loose.
Kevin Gowdy aka Kagey 1999 Polaris Magnum 500
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
