Dirt in my gas tank!!!!
Old May 30, 2001 | 11:41 AM
polarisrules44's Avatar
Recentally while i was putting gas into my quad i noticed there was some dirt that had setteled on the bottom of the tank...What shold i do about this, and what problems can this cause...thanks for any information..
Old May 30, 2001 | 11:58 AM
Cowtit's Avatar
If it gets into the carb, it can cause your bike to run like total crap! If you can't get it out through the gas cap hole, I would take teh on/off/reserve valve off the tank and flush the tank w/water a few times. Then clean the valve in case it already has some dirt in it, put it back together and be on your way. Lata.
Old May 30, 2001 | 01:18 PM
MOUSIN's Avatar
Polaris,
Cowtit is right, you really want to clean that tan out ASAP. My dirtbike friend used a shop vac to clean out his tank. He drain all the fuel out, then vac'd out the dirt. As for flushing the tank and fuel lines, he used gas.
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
