shifting problems on SP500
Old Dec 28, 1999 | 12:06 AM
Jack's Avatar
Don't take anything apart, just adjust the linkage. Ice, usge, wear, new machine, etc. A very slight adjustment will cure the problem, without worring about extreme measures, or something being wrong. There are those in these forums who constantly jump to the extreme wrong conclusion most of the time. Undertandably, they also have most problems, far more than the most of us and it shows up constantly. Save yourself some grief and don't join that group. The fix is usually a lot simpler than you think.
<A HREF="http://www.godigital-design.com/96Polaris.html">Schultz Motorsports</A>
Old Dec 28, 1999 | 01:40 AM
JeremyB's Avatar
Thanks Jack, I'm not really sure I want too screw with the box and all. But I'm almost positive it ice in the box. You can't move the lever at all, in any direction. The only way it will move is if it's thawed out. I post the results when I find out. I'm probably going to take a look see tommrow.
thanks again guys
Jeremy
99 Sp500 1100 miles
Old Dec 28, 1999 | 10:52 AM
Charlie's Avatar
I agree with Jack if its not broke do not fix it. But I have seen several shifters with water in them and one was so corroded it had to be replaced because the operator did the same trick with the torch. Then summer came along and he forgot about it till it siezed up from corrosion. Make sure the boot is not cracked, besides the cover screws coming loose thats the only way water can get in the shifter.Charlie
Old Dec 28, 1999 | 10:09 PM
Bill.Ciliberti's Avatar
Jeremy,though I will admit that most of Jacks advice is VERY sound,he's wrong this time.There's NO slight adjustment problem as Jack seems to think.I know,I had EXACTLY the same thing happen to my shifter.When it freezes outside,the water contained inside the shifter box freezes.When you heat the shifter up,things melt and you can shift again.My shifter screws had worked themselve loose,causing water to enter inside the shifter box.Sorry Jack,but on this one,your wrong.====BILL
Old Dec 28, 1999 | 11:14 PM
  #15
atving's Avatar
Is this a common problem with polaris trans just when I start thinking things are getting better at Polaris something like this shows up...I am not doing this to put polaris down I was seriously thinking on buying a polaris as a second bike to my artic cat...how many people have had this problem so far...thanks
Old Dec 30, 1999 | 05:21 AM
  #16
I had it happen to me this Janurary.I noticed the screws loose,took it to the dealership and they fixed me up pretty quick that time.I knew that water had entered the shifter and frozen.
Old Dec 30, 1999 | 07:49 PM
  #17
JeremyB's Avatar
Well, I took it apart today, and It had a lot of H2O in there. Also another one of those screws on the top of shifter's box was really loose, again. If you have a Sp500 check your bolts to see if there tight. Also my shifter box did'nt have any switches/sensors, in it.
Thanks again
Jeremy
99 SP 500 1100 miles
Old Dec 30, 1999 | 08:42 PM
  #18
Jeremy,I hate to tell you=============================================== ======= ''I TOLD U SO''--BILL
Old Dec 30, 1999 | 08:45 PM
  #19
Looks like Jack put his foot in his mouth this time.[Just teasing you Jack]==BILL
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
