Chain tensioners do they work?
Old Jun 15, 2001 | 02:51 PM
bubba1005's Avatar
I need some feed back from you guys on this. My chain no matter what I do jumps a bit when you hit the gas hard from a stand still. Will this help? I just put a new chain on and after a short ride before my clutch buttons broke and it still did it, and yes the chain was tight at first and now it is allready a bit looser. It seems as though it always wants to be loose enough to slide on the wear pad on the swing arm. My chain is an 8000 lb tensile strength. Which is the same as the DID X-ring.
Old Jun 16, 2001 | 03:01 PM
x_scrambler3's Avatar
what shape are your sprokets in cause if they are wore out that will happen. An yes the chain tensioners work
Old Jun 18, 2001 | 12:55 AM
HyperSport400XC's Avatar
I'm with X_SCRAMBLER on this one. Yes a chain tensioner will work, but only if your sprockets are in good shape.
Old Jun 18, 2001 | 09:59 AM
TheQuadfather's Avatar
My buddy has one on his 97 Sport. He can't seem to keep springs in it. He has gone through about twenty springs since he bought it. He is pretty hard on his machine, though.
Old Jun 18, 2001 | 06:22 PM
ScrambledKiwi's Avatar
I got a 96 Scrambler and have had ot from new. I looked at the HPD chain tensioner, but as I have never had a chain break , derail or skip, I thought what's the point. When I replace a chain, I ALWAYS replace both sprockets at the same time (about every 2 years). The Scrambler is modded, and must be doing about 50-55hp by now. I still use OEM chains and sprockets.
Old Jun 18, 2001 | 06:23 PM
Another thought, check your swingarm bushes, and swingarm alignment. If these are out, the chain will skip and derail.
Old Jun 19, 2001 | 07:58 AM
MaineRider's Avatar
I use Hot Seats chain tensioner for my 96 Sport. Have had to replace it once in a year and a half. It is pretty easy to change though I'm not sure it will fit a concentric drive machine. Part # is ATVCT and costs $49.95. Their phone # IS 651-982-0600. HHope this helps. Oh yeah I agree check sprockets and swingarm am sure its one of those causing your chain to skip.
Old Jun 19, 2001 | 06:52 PM
HPD make all chain tensioners even the one hot seat has. HPD just came out with a chain tensioner for the concentric drive an if the made one for the concentric drive then there is something that is happening that they made them for it. So you can get a chain tensioner for your quad.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
bikedad3
Jul 2, 2015 02:15 AM
