CV boot replacement on scram 500 4X4
Old Jun 25, 2001 | 12:00 AM
ferd350CT's Avatar
Can I replace it myself?I consider myself somewhat mechanicly inclined(I do my own fluid changes,tune-ups).Do I need any special tools?Should I let dealer do it?Any advice would be helpful?Service manual a must? THANKS
Old Jun 25, 2001 | 12:58 AM
Dazed's Avatar
You can do it but you do need a " lb tourqe wrench. Also if you screw it ub you will be spending real big chunk of change to repair your fixxing.
Old Jun 25, 2001 | 07:59 AM
MaineRider's Avatar
Its an easy change. I do recommend a manual though. Had to replace mine three times before I figured out you shouldn't ride in clear cuts in the woods. Am working on making a-arm guards from light weight aluminum. Good luck.
Old Jun 25, 2001 | 09:39 AM
Farmr123's Avatar
It isn't that tough. Take the clamps off the old boots, and take apart the lower ball joint (have the front skidplate on blocks or a jack before you do this). The axle is held into the CV joint by a spring clip. They simply pull apart with a 'pop'. Grease it up (grease may be provided with the new boot, if not get some CV grease at an auto parts store) and put everything back together like it was, being absolutely sure the spring clip on the end of the axle locks into place (usually you will hear it go 'click'). Re-assemble the ball joint, and clamp the boot down good. You are now ready to roll.
A torque wrench is recommended for tightening the ball joint, and CV clamp pliers are HIGHLY recommended.
A service manual is helpful, but in all honesty, the listing in the parts manual you can download from the Polaris website shows how everything fits together and may be enough for this project.
Old Jun 25, 2001 | 08:49 PM
tmbk2's Avatar
Sure you can. The service manual only convers the basics. I only got so much out of the manual and the rest I had to go on intuition. Best advice is if your not confident then pay someone else to bust up their knuckles!
Old Jun 25, 2001 | 09:23 PM
kukerdan's Avatar
about cv boots....
does a 97 scram 400 4x4 have u-joints or cv joints/?
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
