delta v-force reed question?
Old Jun 25, 2001 | 11:16 PM
trailbreaker's Avatar
did anyone notice a power gain or better throttle response by goin to the v-force reed valve?Do you need to rejet after this mod?and do you need a gasket on both sides,engine side i know i'll need one for sure but what about the side with the rubber flange the carb hooks into?
2001 scrambler 2x4
k&n,.190 polished rims[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 26, 2001 | 12:45 AM
NewDSLover's Avatar
I didn't notice any real power gain, but the throttle response was greatly noticed. As for the gasket question, I didn't install one on the rubber flag side. Just a little red gasket maker to help it out. not alot - just a thin coat. But if I was to spend $150 bucks again, would I? No.
One special note:
Let your 2 stroke warm up good before going out. If you don't, your engine could backfire and blow your reeds. I did this(scram) & so did my friend's 400 xplorer.
Old Jun 26, 2001 | 09:46 AM
HyperSport400XC's Avatar
Trailbreaker,
Yes you will have to rejet, but leaner instead of richer. Usually when you do mods to your quad that involves more airflow through the machine, you have to jet richer. Not so with the reeds, you actually have to jet leaner with the reeds. One step on the main jet should do the trick. As far as making it into a monster with just the reeds, it aint gonna happen. You may gain more in the future if you decide to do more mods, but by themselves the difference won't be noticeable.
QuadRiders
Oct 22, 2015 04:13 PM
2many2ride
Sep 27, 2015 04:35 AM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
