backfiring 4oo
Old Jan 7, 2000 | 05:35 PM
eandk99's Avatar
K, guys. Need some input.. Have a 96 scrambler 400.. It has clutch kit, ported, carb bored, pipe, and head mods..
My problem is when i try to run slow, like cruse at 25mph or so.. it stutters sometimes it backfires. If i keep hitting the throttle it is fine... If im running full or 3/4 throttle it runs great????? Everything should be set up right, but...
Any ideas out there?? Would reeds help this??
Its not a bad problem, but very irritating when im riding in the woods and have to keep tapping the throttle..
Old Jan 7, 2000 | 09:44 PM
scramblinman's Avatar
i hae two questions for you: first off how does your spark plug look? sometimes when mine starts to foul it gets a "miss". second, is your plug wire/boot attached firmly and securely? I havd mine start to separate inside the boot and not make real good contact and would "miss" at lower speeds. other than that i don't know what to tell you, unless it is not jetted correctly.....chris
Old Jan 7, 2000 | 11:02 PM
eandk99's Avatar
After it does this the plug does look fouled.. not bad, but... Havent taken a look at the plug boot.. A place to start anyway.. I thought jetting too, But according to Darrell at HPD its all setup right there...
So.... out to the garage..
Old Jan 8, 2000 | 04:54 PM
Pfelect's Avatar
A friend of mine had similar prob with his wifes Scr400(stock). He replaced the reeds but that didnt fix it. Wish I had more info for you.
Ronnie Crecelius Xpedition 425
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
