any hope on patching a tire on the side wall?
Old Jul 3, 2001 | 03:04 PM
patrickvol's Avatar
i have a very small hole on the side wall of my frount tire. i dont know how long it take to go down, but takes w bit to make bubble with sudsy water, and if know hope were is the best place to get a new tire the bike is a 400 explorer 01, and would like to get the stock tire
Old Jul 3, 2001 | 03:22 PM
aar0's Avatar
Yes there is hope. If it is a small hole just go to an automotive store and buy some tire pugs and plug the hole. If it a gash then you can try a tire patch and patch it on the inside and outside. My brother had a 5 inch gash on the front tire of his 400EX with 30 plugs in it. They came out and he put a tire patch on the inside and outside. Just make sure that you clean the tire where the patch will come in contact with it.
Old Jul 3, 2001 | 03:36 PM
scramdaddy400's Avatar
I have an easier solution to this problem, put a tube inside the tire. You should never use or fix a tire with a sidewall puncture, but if it's only temporary until you can get a new tire then you'll be alright.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Jul 3, 2001 | 06:43 PM
txtrailboss's Avatar
Unless you are doing a lot of pavement riding, there wont be enough heat buildup on the tires to worry about running a patched sidewall. Especially since it is a very slow leak. A good repair shop should be able to hook u up.
Old Jul 4, 2001 | 12:19 AM
2000MOJAVE's Avatar
They make a plug/patch. It goes on like a patch, but has a plug that comes through the tire. If it is a small hole, 1/4inch or so it should be fine.
Old Jul 4, 2001 | 10:55 AM
BK's Avatar
BK
If it is just a slow leak, try a bottle of Slime. Takes a couple of minutes to put it in and then you ride it around a little and no more slow leak, or for that matter, future slow leaks. With the stock tires being so soft, I had a lot of thorn punctures. With the slime in, it is not an issue anymore. If you are going to replace the tire, go with the new 6 ply 429 XT. Same price as original equipment in Dennis Kirk, but should take much more abuse.
Old Jul 4, 2001 | 05:13 PM
whaley01's Avatar
I have used a tire patch on the side of my tire. It was a 1/4 hole. The patch has been on their a year now and no problems. But i am planing a trip next week up morth which is about 4 hours. I am having a new tire put on to be on the safe side.
Ripinandtearin
Jul 19, 2015 08:38 PM
rcappie4
Jul 18, 2015 07:51 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
