Sportsman 500 aftermarket tire question?
My brother and I went riding last evening and he ripped a knobby (split) and now he is in the tire market.
1st ?
The machine is 10 hour old and the rip in the tire looks like it was caused from tourque and not a cut. Should Polaris (Goodyear warrauntee the tire?
2nd ?
If he buys tires, how much wider can you go on the front without having tire rub on the strut?
3rd ?
I had Bearclaws on my old Trailboss and wondered if anyone has run them on a Sportsman?
4th ?
Do all Sportsmans have a ticking sound to the engine? Both our machines make the same sounds.
5th ?
I am considering a K & N filter. Do you change the jetting if one is used?
We ran down some really tough trails and the Sportsman really is an incredible machine. I
1st ?
2nd ?
3rd ?
4th ?
5th ?
1: I would try polaris first as long at its under warranty
2: On the FRONT tire i would not go more then 9 or 9.5 it gets to hard to turn
3: Do a search under polaris for the claws
4: Yes, sports mans do make a ticking sound. Mine does.
5:I have a 2000 STOCK sportman 500. I installed the K&N filter. The sports man comes stock with a 152cfm jet. I went to a 162.5 main jet. I also installed the green spring from Ritter Racing. No other mods.
Reason for installing it: Mine seemed sluggish in the mud and at 60%-100% throttle.
Results: With the green spring I can almost flip the sportsman in low gear when doing a wheelie! How ever in High gear I did not see much of an improvement. I don’t know if I was expecting to much. It seems to give just a little more snap off the line. It's not jumpy or jerky. The K&N WITH a jet did make a HUGE difference. The throttle response has largely increased but its not a racing machine. I got what I wanted from the mods, more power under load. I was VERY impressed with the machines performance in thick mud and muck. It was able to keep them tires (stock) spring to the point I could let off throttle then hammer it back and it would speed them up again. The changes I chose made the machine feel lighter in the aspect of power on the low end during heavy throttle.
In conclusion I am impressed with the changes and would recommend it to people that might have experienced the same issues. I no longer lack power when I need it. The total package costs $75 and WELL WORTH IT!
Hope this helps..
I would look at a cluch kit if i were you also. HPD rear roller clutch and the HPD aggressive front cluch.. Makes a bid differance. I have heard of some problems with the Heel Clickers in the front. But the are nice if you get them working perfect.
Hope this helps!
Hope this helps..
Hope this helps!
I went by the dealer and they did not warruntee the tire. After closer inspection with the parts manager we both agreed it was a cut. I got some Super Seal Formula 100 tire sealant that is used in farm equipment and will give it a try. He highly recomended the stuff and said it can seal close to anything. If it does not work I am getting a tube.
