Sportsman power
Old Jan 30, 2000 | 01:10 PM
sixty9cobra's Avatar
Hey people check out page 26 of march dirtwheels. scrambler carb, cam and clucth wheights might be the answer to wake up a sportsman500?
99 Sportsman500,2000 Trailboss 325,69 Mustang 428scj
Old Feb 3, 2000 | 12:44 PM
Jack's Avatar
I saw that. We have changed a few things already, pipe, roller clutch, airbox, tires, etc. We recently have changed the carb manifold and CB40mm carb. Both are from a '99 Scrambler 500HO. The problem with that carb is there are no other needles made for it. We need needle that is one step leaner since we're on the last clip right now. Talked to the Mikuni folks last week and they said the only thing we could do was to chnage the needle jet itself and go leaner. We have a couple needle jets coming and will try this out as soon as they are received. Other than a little right right now in the mid, it runs absolutely great.
With the cold weather and snow, we haven't been able to evaluate performance very well, but we'll get there.
Our next step will be going to the 500HO cam and the Wiseco 10.5:1 piston. The cam is cheap enough @ $140 and the intake and exhaust valves along with the springs are all the same. We'll have to change the jetting again when we do this, but at least we should have some room on the needle to compensate for it. I probably won't install the cam and piston until late winter or early spring.
[url=http://www.GoDigital-Design.com/Schultz Motorsports[/url]
Old Feb 4, 2000 | 07:57 AM
Thanks Jack will be waiting.
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
tweeder
Jul 5, 2015 01:57 PM
