Scrambler 500 25" tires
Old Jan 31, 2000 | 10:16 PM
Y2K_Kodiak's Avatar
can you put 25" or 26" tires on this machine without a hit in performance. and with the tires from the factory being diffrent size do you need to change gearing to run same size front and rear?
Old Feb 3, 2000 | 10:33 AM
myscrambler's Avatar
Yes, you can put 25" tires on the Sc500. I already had a FMF MegaMax II pipe on it before I added the tires so I could barely tell that I added the tires (speed wise). It handles better than stock. I love the ground clearance, it is more than I had on my Sportsman 500, plus I can keep it in two wheel alot more. It's funny to go riding with alot of Polaris and be the leader because the stock Scramblers will get hung up and I won't even touch bottom. Then I get these guys on Sportsmans and Magnums that think no scrambler can go thru what they can but then I go thru more then them and really make them look bad. I am not a show off but when trash is talked I perform. I did not have to do any gear changes to run 25s (f) and (r) although I did move my floorboards forward and out by an inch for more clearance between the tires. I would not go back to stock sizes for anything, I go too many places tooo easily with the larger tires and I can still race you through the woods and beat ya. I have added an aggressive clutch kit and roller clutch so I move pretty quick when I need to. Because of the pipe, clutch kits, and tires I can out perform the stock scrambler easily except on a motorcross track than I would choose a different atv. I am very happy with the tires 25" bearclaws but I think I will go up to a 26" (f) titan 589 and 25" (r) 589 for my next tires. Check out a few pics below to see the Scrambler 500 on 25" bearclaws. BTW The awd works great so the tire ratio is not a problem, I did notice the front wanted to stay locked in during these big snowfalls, I think something was freezing causing it to stick, no big deal just put it in reverse and kick it then the front unlocks.
Later,
Old Feb 6, 2000 | 03:16 PM
Jeremy H.'s Avatar
myscrambler, what size titan 589 are you getting? 26x?x? (f) and 25x?x? (r). I am thinking of larger mud tires for my scram 500. I just wondered what might work the best?
Jeremy 99 500 HO
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
switzomatic
Aug 24, 2015 12:57 PM
mitchxc700
Aug 19, 2015 02:41 AM
maxjung
Jul 13, 2015 05:11 PM
