problems with 35mm flat slide fitting t.b.
I purchased a new 35mm flatslide for my trailblalezer yesterday and mounted the adapator plate on my cylinder and then i put on the carb.My t.b. is 1998 and the float bowl rubs the transmission so it is on there at an angle and it still wants to rub the tranny.My question is can the adaptor plate be milled down so it will clear or does anybody have better thouts on what I should do?I will say it helped out my performance alot. Thanks for the help because I could use some.
