Sportsman 700 Problem
Old Oct 13, 2001 | 11:35 PM
Mumbles's Avatar
Just got a new 700 last Weds. but never got a chance to really drive it untill today. I went a whole 4.8 miles and it shut down..just as if I had turned the key off. I found it to be a no spark problem. After it cooled down for 20 minutes..it fired up and ran like a top for about another 4 miles, then shut itself down again..no spark. After a 20 minute cool down, away it went again. Had a hell of a time getting home with the darned thing shutting down every 3.5 to 4 miles. I think it`s either the coil pack,stator, or pickup coil. Anybody else heard of this or have any ideas?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 14, 2001 | 12:36 AM
Quadfather's Avatar
I had a Suzuki Quadsport that did the same thing. As soon as it warmed up, it shut down. It was the coil.
Old Oct 14, 2001 | 06:55 PM
RacerX's Avatar
Just a longshhot but possible quickie fix, I had a similar problem on a SC500 and SP500. Turned out to be a pinched gas tank vent line. Acted just as you described.
If you can't see the line itself, take a ride with the tank lid loose.
If its not this I'd get it back to the dealership.
Good luck
Old Oct 15, 2001 | 04:34 PM
Jack's Avatar
Hmmm, sound like another Polaris performance legend in the making . . .
This forum would be about the last place for one to ask for good info. Have you though about calling the dealer?
Old Oct 15, 2001 | 04:42 PM
pathfinder95's Avatar
i
Old Oct 16, 2001 | 03:42 PM
Grizzlyman1's Avatar
The problem might be an coolant fan relay/fuse problem, causing overheating. I read about that problem on another site, and it overheated a few times on him, causing the seal on the motor go to and getting coolant into the engine block.
Old Oct 16, 2001 | 11:31 PM
Mumbles's Avatar
Turns out the stator has a broken wire. Hope it doesn`t take forever to get a new one!!
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
