front brake rattle?
Old Dec 1, 2001 | 02:20 AM
boneylong's Avatar
my 99 xplorer has rattled since day one .the pads have a little slack in them and they rattle.anyone elses do this??
Old Dec 1, 2001 | 10:02 AM
motorman's Avatar
mine click and i thought it was the bearings till i checked into it.
Old Dec 1, 2001 | 09:36 PM
Cruiser's Avatar
Sounds the same as my Trail Blazer. Problem was a warped rotor.
Old Dec 1, 2001 | 11:05 PM
jakyl's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img] sounds like you need new roters. go to discount furniture ask for reed,he will fixx you right up!!!
Old Dec 2, 2001 | 12:01 AM
boneylong's Avatar
i talked to reed and he said he was busy working on a 97 magnum@!!!!!!i will try again when i go back to pick up my couch!
Old Dec 10, 2001 | 10:34 PM
shoer's Avatar
I had the same problem with my 1999 Sportsman 500. I took the brake
apart and saw it had an adjustment set screw on the back of the caliper. By turning it in counter-clockwise about a 1/4 turn, it closed up the slack between the brake pads and the rattle stopped. It puts pressure on the brake pads so they may wear out sooner but it stopped the rattle. I don't know if your Explorer has the same adjustment set screw or not but you could look to find it. Hope this helps you.
Old Dec 10, 2001 | 10:43 PM
kukerdan's Avatar
i had there, there are 4 screws that need to be tightened behind the hub
Old Dec 11, 2001 | 11:23 AM
uflg95's Avatar
The allen screw in the caliper should be adjusted every so often. I adjust mine about once a month and this will help rear pad life by keeping the front pads adjusted properly. Jack up the front of the quad, spin the tire, screw the allen screw in until it stops the tire, and then back the screw off 1/4 turn or when the wheel spins with very little drag. Doing this will help both rear pad life and keep those rattles away.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
Mikesohio
Jul 26, 2015 10:51 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
