break in
Old Feb 5, 2000 | 11:29 PM
Jerrod695's Avatar
Im gettin my new trail blazer and i was wondering if it is ok to break it in in cold, snowy weater and how long will it take to break in?
Old Feb 6, 2000 | 02:33 AM
SportKod's Avatar
Make sure you let the engine warm up completely before taking off and gassing it. A good 4-5 minutes. One tank of gas is all it needs for breaking in. Take it easy on the first tank.
Old Feb 6, 2000 | 07:58 AM
Rammer's Avatar
SportKod that's good advice. Also vary the throttle to keep engine from running at the same RPM for amount of time and avoid wide open running on the first tank. Take breaks often to let motor cool down and then run it some more. That seems to help break in too.
Old Feb 6, 2000 | 08:05 AM
Rammer's Avatar
Somthing I forgot: Make sure oil level had dropped to verify that oil pump is working.Check the clear oil line for air pockets, if so then bleed oil pump. Do this on the first tank because dealer adds oil to gas.
Old Feb 7, 2000 | 12:29 PM
cowchaser's Avatar
i just got mine about 6 days ago. they are right make sure it is warm. and the only thing i didnt like about the break in is it took forever(thanks to the 4 gallon gas tank). but its worth it.
Old Feb 7, 2000 | 01:59 PM
Odin's Avatar
Make sure your dealer put the extra 12oz. of oil in your gas tank in case oil pump has air in the line. This will save your engine from a melt down. Burning the extra oil will not hurt the engine. I have done this on all three of my 400 Polaris two strokes. Also check your oil reserve after your first tank of fuel to check and see if the oil injection is working.
Old Feb 7, 2000 | 04:40 PM
RobCulp's Avatar
Make sure your dealer has made the necessary carb adjustments for cold weather riding.
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
atvcollector
Sep 8, 2015 05:11 PM
