Drive Belt Problem...
Old Dec 24, 2001 | 01:48 AM
Cincinnatimddr's Avatar
I bought my '00 Scrambler 500 4 X4 used, 3 months ago used. I had to replace the belt and now I'm having all sorts of problems. It started making a noise as if the belt was rubbing the outer cover.It has since wasted the NEW Polaris factory belt. Is is a clutch problem? An alignment problem? Or a ? problem. I bought a Clymer manual and it doesn't seem be much help. Once before it chewed up my belt, the belt had completly reversed itself while riding. I would greatly desire some feedback. Thank you..
Sean [img]i/expressions/face-icon-small-sad.gif[/img]
Old Dec 24, 2001 | 09:48 AM
ftwflh's Avatar
check your motor mounts,THen make sure your cover isnt warped.if this is all ok check allinement of clutches. -----Brad-----96 425 Magnum-----96 400 Sportsman---2001 Yamaha Breeze
Old Sep 2, 2003 | 01:02 PM
rtmt91's Avatar
Default Drive Belt Problem...
I am had the same issue on my sportsman 500... my belt inverted (flipped) during ridding
What did you do to fix it?
Ridgebackguy86
Sep 19, 2015 12:48 PM
patrick.oc123
Sep 16, 2015 03:45 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
