swingarm bolts
Old Dec 30, 2001 | 04:05 PM
kukerdan's Avatar
what size are they and whats the thread? that way i can buy all steel locking nuts instead of using whats on there, any tips for this procedure would be welcome
Old Dec 30, 2001 | 08:54 PM
Farmr123's Avatar
The non-concentric models are 1/2 inch bolts, standard right-hand thread.
Get a grade 8 all-steel locknut if you can find one, and use loctite, those things are a devil to keep tight.
Old Dec 30, 2001 | 10:10 PM
kukerdan's Avatar
whay typr loctite should i use? obviosuly not permanent, should i use high or medium , and where can i buy a locking nut
Old Dec 31, 2001 | 09:54 AM
Farmr123's Avatar
I did this on the old Xpress I used to have, tightened up the swingarm after the bolt on the right side came loose, that is.
Make sure that the ear on the frame didn't wobble out. If it did, you can weld a washer there that has a hole that fits TIGHTLY to the shank of the bolt. Someone had said a small block Chevy flywheel or counterbalance washer is a perfect fit. Then be sure the bolt isn't worn down. If it is, you might consider a new bolt if it is very bad.
I used the high-strength loctite, and got the all-steel locking nut at an implement dealer, I believe the Case-IH place. Either them or a John Deere (Or whoever) dealer should have them, as they are a common size, and are used fairly often on tractors & such.
I don't know how hard it would be to remove the bolt after that, because mine never needed anything done to the swingarm after that (had 6500 miles on it when I traded for my Xplorer).
Old Dec 31, 2001 | 12:40 PM
kukerdan's Avatar
thanks
Old Dec 31, 2001 | 12:55 PM
Farmr123's Avatar
By the way, usually only the right side works loose. If the left side is tight, it is usually best to not mess with it. You have to take a lot of stuff off to get to the bolt, wheras the right side is fairly easy to do.
Old Dec 31, 2001 | 01:19 PM
kukerdan's Avatar
so, ive heard, [img]i/expressions/face-icon-small-smile.gif[/img] i hope its the right, how can i tell which is loose
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
