250 Trail Blazer backfires and loss of power
Old Jan 3, 2002 | 11:52 PM
muder's Avatar
Ocasionally my Trail Blazer back fires and I momentaily lose power? I have changed the spark plug seveal times. However, my battery is weak and no longer holds a charge. I understand that poor or weak battery can cause weird things to happen on Polaris's. Could this be the problem?[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 4, 2002 | 04:20 AM
ScramMan's Avatar
This may be a stupid question, but have you checked the air filter? My Scrambler 400 does the same thing when the filter get's dusty. It may not look that bad, but if you take it out and blow it out with compressed air, you will find that there is alot in there. Hope I helped.
Old Jan 4, 2002 | 05:51 PM
sparkys's Avatar
If its doing it when you let off the throttle it is because the throttle cable is too slack and the throttle kill switch is disengaging.It will momentarily kill the ignition until the throttle closes and then it will start to fire again. This will cause the backfire.By the way , backfiring on a 2 stroke isn't a good thing. It can easily blow out a crank seal.
Old Jan 4, 2002 | 06:25 PM
ftwflh's Avatar
If you dont get your battry replaced you will be replacing EVERY light bulb on the thing.I had to do this because of a bad battry and the bulbs cost more than the bat did.
Old Jan 4, 2002 | 08:28 PM
tom18801's Avatar
my dads 250 trail boss backfires and looses powerlike you said yours does and i found out it was the silencer there is a bolt on bottom tha has to be in or it backfires
Nondem
Feb 22, 2020 12:20 PM
greg74
Sep 10, 2019 03:03 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
Gnuters
Jul 19, 2015 10:03 AM
Chocobamofo
Jul 10, 2015 07:46 PM
