Split Brake for 2000 Scrambler
Old Jan 21, 2002 | 08:23 PM
fourjs's Avatar
Just purchased the split brake kit from hotseat for a 2000 scrambler, has anybody installed this unit, if so, any short cuts or difficulties in installing and did you like it afterwards?? thanksin advance.... ..
Old Jan 21, 2002 | 08:45 PM
Ronnnnn's Avatar
installs easy, take your time, do it right, you will have to bleed your brakes several times to get them hard, if separate front and rear brakes are what you want then it will be a great hop up.
YOu can take off your foot brake pieces and run a tee in the back so you can use both pistons of the master cylinder with the hand lever.
scram5050
Aug 30, 2024 01:39 PM
Njrider1230
Jul 29, 2023 05:16 AM
scram5050
Aug 19, 2015 02:19 AM
DeFox500
Jul 26, 2015 06:32 PM
