'01 HO shifting problem
Old Jan 25, 2002 | 06:41 PM
samurai's Avatar
Anyone have a problem with their '01 HO shifting **** coming out of gear or difficulty getting into gear? any info would be greatly appreciated. It pops out of reverse and is tuff finding and coming out of lo.
Bob
Old Jan 25, 2002 | 07:22 PM
Archer1231's Avatar
Yes, I had the problem last year. The dealer first tried adjusting the shifting linkage. Sounds obvious, but this did not work. He changed my transmission belt and this worked. He said that he had seen several Sportsman H.O. that were brought back and had a slight mfg defects in the belts. He stated that this defect caused the transmission belts to grab prematurely. You can check it out by putting your H.O. in gear. If it moves then you likely have the defect as well ( or your RPM are to high ).
Hope this helps.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
