Chain Guard on Scrambler
Old Mar 8, 2002 | 11:09 PM
AdamScramblr400's Avatar
My chain guard, you know, the black plastic one on the bottom of the swingarm fell off, thats right, fell off. Is it okay to keep it off, or should I put it back on. It has been off for about a month, and so far, so good!! I have a moose swingarm guard also, and it doesn't bother it.
Another question, tommorrow I plan on taking my swingarm guard off, and drilling quite a few holes in it to let water out, and to loose weight. Good idea, or not?
Old Mar 8, 2002 | 11:14 PM
Quadfather's Avatar
I drilled a couple of holes in mine when I first got it, to drain water. It worked perfectly.
Old Mar 8, 2002 | 11:18 PM
Cool, what kind do you have? I accidentaly over torqued the bolts, and they are now part of my skidplate. Guess I'll have to do some grinding while I have it off too!
Old Mar 9, 2002 | 12:08 AM
modquad's Avatar
Adam, most will run w/o the guard after doing a lot of mods. Even if the chain starts tagging either the swingarm, or the guard, you can install squares of teflon for them to skip across. I've got to get around to some drainage holes also. Also to save some wt. you can remove (if you haven't already) those heavy brake rotor and rear sprocket protectors.
Just my 2c,
Ken
Old Mar 9, 2002 | 03:53 PM
I took off my sprocket guard, Is that the only one, or is there a brake rotor guard too??
exmotocrosser
Sep 13, 2019 06:12 AM
kbazzy
Sep 26, 2015 11:26 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
merryman
Sep 19, 2015 03:15 AM
