Diode size for reverse limiter button?
Old Mar 14, 2002 | 01:59 PM
SnowDrift's Avatar
Is a 20 amp the correct size of diode to use for overriding the reverse button to be able to use 4wd in rev. without pushing the yellow button? Or is it 2 amp? If it is a 20 amp, then where should I find one? Radio shack carries a 2A, but that is about as big as they go from there.
Thanks,
SnowDrift
Old Mar 14, 2002 | 04:07 PM
waterbuffalo's Avatar
Side Cutters Work Well
Old Mar 14, 2002 | 09:18 PM
Sportjet's Avatar
I believe I read somewhere that the 20 Amp was a misprint. I think 5-6A was OK and you could wire 3 2A diodes in parallel to get you there.
20A is a huge diode.
Njrider1230
Jul 29, 2023 05:16 AM
house1
Aug 9, 2015 10:49 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Scottma518
Jul 10, 2015 12:42 AM
