RCR air box mod.
Old Mar 24, 2002 | 02:59 AM
sevy's Avatar
I ordered the HPD Trail pipe that comes with the correct jets, but i am thinking of getting the RCR air box mod. Will i also have to rejet after instaling that? I am very new to the 2 stroke and i don't want to fry my new engine because it's to lean. Thanks in advance.
Old Mar 24, 2002 | 03:20 AM
modquad's Avatar
Always error on the side of caution. More air in, means you'll need more fuel also....you are correct. The airbox mod Rick sells is great for maintaining mudding protection. If you don't do too much muddin', have you thought of removing the airbox and installing a cone K&N with a water repellent Outerwear? Lots of different avenues, just throwing out some suggestions. You can also modify, or remove the inner plenum.
Good Luck,
Ken Thompson
Old Mar 24, 2002 | 03:31 AM
sevy's Avatar
Thanks Modquad, Rick i'm sure could point me in the right direction if i tell him what i have. He is a great guy to talk to.
Old Mar 24, 2002 | 10:40 AM
Todd400's Avatar
I was running a 250 main with the HPD pipe and recently had RCR bore my carb and send me the airbox mod, I went to a 280 after the mod and it seems spot on in my neck of the woods, It definetly flows alot more air with the RCR mod[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 24, 2002 | 07:31 PM
Quadfather's Avatar
You can do the air box mod yourself if you have a 3 inch piece of
2 1/2" PVC laying around. It will save you $35, if you already have a high flowing air filter.
Old Mar 24, 2002 | 08:58 PM
Todd400's Avatar
Yeah I run a K&N and ordered the kit minus the filter for $15, He gives you an aluminum neck a extra venturi and the needed clamps and instructions, He even threw in a couple extra jets at no charge, Rick is a real class act[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 25, 2002 | 12:03 AM
sevy's Avatar
Thank you guys for the info, i'm going to call first thing in the morning.
ProtegeDK
Feb 18, 2002 11:53 PM
sly
Aug 23, 2001 12:45 PM
adamnieman
May 5, 2001 10:29 AM
