trailblazer jetting problems
Old Apr 21, 2002 | 12:08 AM
BeastyTrailblaizer's Avatar
today i rejetted my trailblazer and it seems like it is getting too much fuel. i modified my airbox to obtain as much air as possible and it still seems to be getting too much fuel. does anyone know how to fix this?
Old Apr 21, 2002 | 12:38 AM
Ronnnnn's Avatar
If your jetting is rich then to fix the problem you must lean the jetting.
Old Apr 21, 2002 | 12:55 AM
well thats kinda facking obvious but i wanted to know if there was any other ways around it. by the way i only went from the 130 jet to the 150.
Old Apr 21, 2002 | 10:27 AM
Ronnnnn's Avatar
Well lets see, I am going to write this slow so keep up, you increased the air into your carb, you rejetted to compensate for this, now your quad is getting to much gas, well, maybe you rejetted to big, or fat, or rich, so now you should jet leaner, all the while checking your plug to ensure you dont go to lean. Or you could plug the holes and put the stock air filter back on and return to the jetting you had before.
Old Apr 21, 2002 | 11:49 AM
biggin's Avatar
Ronnnnn, don't waste your typing to a$$holes who do not appreciate advice when they get it. He asked a question, you gave an answer. Let his weak trail blazer run like crap! Thanks for the jetting tips on the 400L. I went up 1 size problem got worse, so I dropped down 2 sizes and the sport screamed from the start.Beasty, you need to get lost or lose the attitude, you are the first in this forum to be such a turd to someone trying to help!
Old Apr 21, 2002 | 12:14 PM
Blazer250's Avatar
Maybe try the 140 jet. If it's still getting too much gas then go to a 135, but if it's not getting enough go to 145. Just make sure you check the plug.
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Jul 16, 2015 10:29 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
cSchwartz
Jul 9, 2015 02:43 PM
