Seating tire beads....
after you use a lot of air pressure to seat a bead,let the pressure down to what you will run and check the circumfrance of the tire with a tape because all that pressure will stretch the tire and i have seen 1" difference between 2 tires after seating with high pressure. you may have to use higher pressure to get the other tire to stretch. this is a old racer trick the get the proper stagger in a set of tires.
took about 50 pounds to seat my 27 inch 6 ply swampro's been beating them hard for a year now and there fine I will say the longer they took to seat and as the pressure went up and up the longer my arm got trying to stretch away from the tire I know the pow is coming but it still makes me jump everytime
Logan Collins
Sep 5, 2015 08:03 PM
