scambler creeps in gear
Old May 3, 2002 | 10:20 PM
ferd350CT's Avatar
I just had a new belt put on and it squeaks in nuetral. When I put it in drive it wants to go. The belt in obviously to tight. The mechanic(back yard) told it just needs to break in. Sound like bull to me! How do I adjust? Same as car belt? Any help would be appreciated. I dont want to bring back to him,I want to ride now!Thanks
Old May 6, 2002 | 12:10 PM
DaveB's Avatar
You need to adjust the secondary shiv width. The proceedure should be in the owner's manual. Verify that you have the correct belt first.
Old May 6, 2002 | 11:59 PM
Rainman's Avatar
My scrammy did this when the primary clutch spring broke!!
Rainman
Old May 7, 2002 | 01:32 AM
WIscrambler's Avatar
If it's creeping in gear, maybe the idle is set too high and engaging the clutches. You probably have to shim the secondary to eliminate the squeaking.
Old May 14, 2002 | 08:14 PM
Bubba297's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img] Hey Ferd, I am taking it the clutch kit was installed on a used setup. That would explain alot. Proper belt deflection is 1&1/8 to 1&1/4 inches. lay a good straight edge across the entire belt top and lightly push down on the middle of the belt. if it is less than 1&1/8 inch, then something is not right. Make sure it is the right belt first. If it is, you will have to remove the secondary clutch, separate it, and add shims one at a time until you reach the desired goal. One shim MUST always be left in place. One of these should fix you up. Hope this helps, Bubba [img]i/expressions/face-icon-small-smile.gif[/img]
lonerider856
Oct 13, 2023 03:45 PM
bvandass
Oct 8, 2015 09:13 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
