5 days/550 miles on new SP700
Old 06-14-2002, 06:28 PM
northstar's Avatar
hmmm...27 inch tires. The tire has a considerably larger diameter, effectively changing the gear ratio and the amount of RPM required to maintain a particular speed. That tire goes much farther in one revolution than the stock 25 incher did. After turning the tires a lot of times, that starts to add up. A large tire is effectively giving you an overdrive, bringing down your RPMs, hence, using less gas.
ReconBayou
10-31-2022 05:37 PM
dannytas
09-26-2017 06:31 PM
Ahtatu
09-28-2015 12:14 PM
exmotocrosser
09-26-2015 08:18 AM
cboler9
09-24-2015 08:35 PM
Quick Reply: 5 days/550 miles on new SP700
