Need wire / rev limiter info
Old Jun 3, 2002 | 08:54 PM
PolarisPower500's Avatar
My Scrambler still bogs down in water as stated in a previous post. When I bought the quad, it had a twist throttle on it. This eliminated the ETC. I rode it in water many times with that set up and it worked fine, no bogging in water. I put the original thumb throttle on and I have some reason to believe the ETC and/or wiring is cutting engine spark. There is a black wire coming from the throttle and 4x4 switch. I think that same black wire plugs into the rev limiter. If I unplug that wire, will that disable the ETC? I want to eliminate any possible way the electronics could cut the spark.
Old Jun 3, 2002 | 10:36 PM
ftwflh's Avatar
If it goes from the revers limiter to the wire block thats the one to pull.
skinnyr6
Aug 25, 2023 02:18 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ramman1
Jun 16, 2016 09:07 PM
DeFox500
Jul 26, 2015 06:32 PM
ltrmc02
Jul 22, 2015 04:50 AM
