100 yard times
Old Jul 2, 2002 | 01:24 PM
  #41
Bubba297's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img] Jay, I would just try the blue spring first. My wheeler starts engaging at about 3300 with the blue and s-55 weights. I am running the tight side tolerance on the belt deflection,though, about 1&1/8 inch. Did you know you can also increase engagement by using the race weight (10A) and running the stock washer on the clutch bolt? That keeps the clutch farther apart initially. It doesnt affect operation,either. But since you are already about the same engagement with the gold, I would just try the blue first. If that doesnt work, I would check with Mike first before going lighter on the weights. You'll lose acceleration with the lighter weights. I would go up to the violet primary and just adjust the weights to fine tune RPMs. What do you think?Bubba
Old Jul 2, 2002 | 10:51 PM
  #42
pudjumper's Avatar
Wow....Bubba....I would have figured that the Blue would have higher engagement than that. One our tachs must be off and is probably mine. I noticed that you engaged higher than I at Lil Sahara. A big 10-4 on the fine tuning......these ol Pols can be tricky. I'd say go ahead and try the violet.....it can't hurt anything. If it doesn't work go back. I'm getting a pretty good selection of clutch parts laying around here.
Old Jul 3, 2002 | 09:43 AM
  #43
Bubba297's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img] Jay, i bought the battery eliminator from white brothers. Dont go spending the 25.00 plus shipping to do it. It is simpley a DC polarized capacitor. 4900uf at 50Vdc. It is about 3 inches long and about 1&1/4 inches in diameter. Hook the negative side to ground and the positive hooks to the old small red charging wire that hooked to the solenoid along with the battery cable. It just loads the charging system a little bit to keep from burning it up. You should be able to buy the cap from a local A/C service place or industrial supply place for about $5-$7. Just keep it mounted away from the heat. Bubba
Old Jul 3, 2002 | 09:45 AM
  #44
Bubba297's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img] Jay, also I forget to tell you, My wheeler starts real easy with the pull starter even with the 15:1 head on the big bore.Go ahead and gut it like you know you want to!!!![img]i/expressions/face-icon-small-wink.gif[/img]Bubba
Old Jul 4, 2002 | 12:50 AM
  #45
modquad's Avatar
Mine starts the first pull every time with the 15.5:1 dome. Now if I could just get rid of the annual 4th of July gremlin...last year blew open a pipe, this year had a tink, tink coming from my secondary clutch. Broken roller...pretty good for 1.5 years of running it hard.
Ken's personal fireworks!!!!
Old Jul 5, 2002 | 01:01 AM
  #46
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Hey pudjumper
Come to St Joes this Sat July 6 .I will have my radar gun and I will clock your bikes for mph.
I will be in the black duely and long white trailor. I know you will be able to find me, I'm the one with the blue bottle on the front of my DS.
Thanks
J Ross
Old Jul 5, 2002 | 11:48 AM
  #47
pudjumper's Avatar
THEBOM....I was thinking about riding Saturday. Maybe we can get Daren to come and play. I heard you got your DS running strong. See you Saturday.
Old Jul 5, 2002 | 02:00 PM
  #48
scramblered's Avatar
the hpd roller secondary didn't last some months of riding...
Old Jul 5, 2002 | 02:05 PM
  #49
from what i heard from different clutch kit on the market you're better keeping the rpm close to 3500 rpm (not +) at engagement on the 400 scrambler,it snap a lot more at 4000 rpm but you'll loose some usable bottom end power on the trails,it all depend on what type of riding you'll go through.
Old Apr 20, 2003 | 11:27 PM
  #50
duneaholic's Avatar
Default 100 yard times
Just got back from the drags at Texas Sand Drags and had a really good time. My fastest time was a 5.86 at 52mph. Best 60 ft time was a 2.045. Best reaction time a .422. This sport is really addicting. I think with a wheelie bar I could get into the 5.6 range cause I had to kinda go slow into the throttle at first then get on it or it would wheelie pretty bad. Thanks for the great port job Rick it made a big difference. My buddy has a Raptor with a yoshi header and pipe with a pro-flow air filter and I beat him almost everytime. He couldn't believe he got beat by me cause that NEVER happened before I got the port job, head mach. etc.... Thanks. Shawn.
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
