Thinking about getting cylinder ported......
Old Jul 7, 2002 | 05:26 PM
adamnieman's Avatar
Right now I love the way my Scrambler is running, but there is always the need for more right? I was thinking about rebuilding the top-end this winter and porting is the next step in my engine modding.
Besides removing the cylinder and sending it away, what else needs to be done? Is the cylinder bored to match the new piston? I am running a high compression head right now so modding the stock one will not be needed. Will I need a bigger carb or is boring the stock one "good enough"?
Most likly I will send it to RCR for porting. Any suggestion? What has worked well for you?
'96 Scrambler 400 4X4
HPD Trail Pipe/FMF Turbine Core II
HPD Agg. Clutch kit
K&N filter
Boyesen Power Reeds
HSP billet head
Wiseco piston
Old Jul 7, 2002 | 10:44 PM
Snoopy61's Avatar
Iwent with RCR porting myself. The best thing to do is call Rick and tell him exactly what kind of riding you will be doing and what kind of performance you are looking for. He will not sell you something you do not need. Rick will make sure you get what you want. He has the best service of anybody out there. When my cylinder was finished he called me at 8 oclock at night to see if I needed anything else. He will talk to you at any time if you have any problems. He is a super nice guy.
Ronnie
Old Jul 8, 2002 | 08:37 AM
Mike Chero's Avatar
Adam,
I too went with RCR porting. Yes, the cylinder is bored for the new piston. Rick will also save you the trouble of having a melt down. He stocks Swaintech coated Wiseco pistons. Get one!!!! I can't say enough good about them. I would suggest a new carb too. The 39mm PWK Kehin flows the best and is probably the most predictable on the market.
Old Jul 8, 2002 | 01:33 PM
scramblered's Avatar
yeah,a good porting on this fuji 380 make it more performance oriented for sure,go with HPD the trail porting add 8 peak hp!
Old Jul 8, 2002 | 04:19 PM
MegaCrash's Avatar
Also get another carb, if for nothing else, you will know its designed to flow the right ammount of air and fuel. When you get that far from stock, jetting can get a little finicky.
Old Jul 20, 2002 | 05:21 PM
TINKERMAN's Avatar
I had my ported when I board it .20 over.the port work made a huge dif. in the responce.
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
NatePerz
Jul 27, 2015 03:27 AM
ltrmc02
Jul 22, 2015 04:50 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
