pwk 39 keihin carb tuning/trail mod?
Old Jul 17, 2002 | 05:00 PM
  #21
modquad's Avatar
First off, thanks for the complement Scramblered, but I'm just an regular Joe, just havin' fun with da quad. Bubba, my clutching is as follows.
Primary: Light blue spring and 58 wts.
Secondary: Gold spring #3 hole sheave, #2 hole in the helix. HPD roller helix 42-38. I originally had the 56's in for wts, but after some of my running, and then bringing it up to HPD to get things double-checked, the wt change was recommended. We even tried a steeper helix because the engine was over-powering the clutches...complements to HPD's porting and pipe. That's also where the comment that ATV Sport made about my clutching was kinda taken offensively by HPD...they've worked hard and long to get these motors screaming.
As I said earlier, watch your clutches using those kevlar belts. The belts last, but at the mercy of bad clutch wear. With everything else changed over, I can't wait to get this thing to the strip and pull the trigger. Ben and the guys at MAC Racing just machined almost 2 more lbs off the flywheel!!!! Zoom, Zoom, BABY!!!!
Ken
Old Jul 17, 2002 | 05:18 PM
  #22
scramblered's Avatar
flywheel machining off again!? i run the HPD race one wich is 2.3 lbs lighter,so it turned out at 4.3 lbs,i want one right away...
Old Jul 17, 2002 | 07:51 PM
  #23
Bubba297's Avatar
Ken, I would assume you are running the polaris gold secondary spring. Makes sense that you have clutch sheaves worn down. That's a heavy weight and alot of spring to overcome on the secondary. But if that's what they had to do to get it right, so be it. Luckily, I got ahold of a very low hour bike, so maybe it will be awhile before I get into replacing. And scramblered, it you took over 4lbs off the flywheel, there would not be anything left. Rick Ritter took 2.5lbs off of mine, and it would be dangerous to go any farther than that. Bubba
Old Aug 2, 2002 | 06:33 PM
  #24
can someone tell what is the jetting setup (pilot/needle/main jets) size you're running on the pwk 39,have HPD trail mod engine with race
pipe,v-force 2 and reed spacer,no airbox...thanks.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
