Nuts
Old Jul 26, 2002 | 04:50 PM
okiedude's Avatar
There are SEVERAL different types of lock nuts. One of the most common is called a "flex" locknut. It has no nylon in it. The flex are found on older exhaust manifolds. Fastenal should have them.
Old Jul 26, 2002 | 07:25 PM
evan's Avatar
Old trick if you can't find a locking nut.
Take a proper size nut, put it a vise and gently squeeze it until it is slightly oval. Doesn't hurt the threads but is a little work to get on. Should hold though. I've done it at work a few times.
Old Jul 26, 2002 | 08:28 PM
RINCON's Avatar
will thread lock not work????
Old Jul 26, 2002 | 08:32 PM
evan's Avatar
Yep you bet. But it won't be quite as reliable as a locking nut. I've seen supposedly permanent loc-tite not hold in certain situations. Best solution use both.
Old Jul 27, 2002 | 11:30 AM
  #15
RyGuy660's Avatar
If possible, you really should see if you can use a slightly longer bolt and "double nut" it. We use two nuts on pretty much every crucial part of our race car, and havent been let down. Hope this helps!
speedbuff
13
Nov 11, 2020 10:16 AM
raman8tor
Sep 20, 2015 07:35 AM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
