Anybody know how to get the axle out???????
Old Mar 16, 2000 | 09:56 PM
myscrambler's Avatar
Does anybody know how to get just the axle out of the carrier and swingarm on a scrambler 500? Or any polaris axle? I have a new axle but I can't get the old one out.
Please help,
Old Mar 16, 2000 | 10:31 PM
trailblazer00's Avatar
myscrambler,
I've taken the one out of my trailblazer twice so I should know. I'll u do is take off the sprocket and the rear brake and the brake disc. For the brake dont take the bolt out that holds the brake around the carrior just loosen it, take the 2 bolts on top of the brake thing. And it should just come off and just set it on top of the swingarm. You can get the sprocket off without taking the guard off. Loosen the back bolts and take them out, the ones that u have to loosen to tighten or loosen the chain. so u can take the chain off. After u take off the sprocket and the brake and the disc there is a housing thing over the big nuts on each side of the carrior. They are held on by an o-ring on each side. Take the o-ring off and the housing over the nut should come right off. loosen the nut on one side or since your putting a new axle on takem both off. Watch though they are pretty tight. Me and my dad used a pipe wrench on each side to take the nuts off. And the axle should slide right out. Hope you can understand the directions if you don't get it out post it and mabe I could tell you whats wrong or whatever. Hope this helps. Oh take the tires and the hub off first! LOL
Old Mar 16, 2000 | 11:21 PM
I have the cover over the big nut off on one side but it will not budge off of the right side. Well it seems I am doing it right but the one cover is stopping me. I have been out there for over three hours pounding on it with no luck. Thanks for replying so at least I know I am heading in the right direction. How did you get the covers off, just slide them???
Thanks again,
Old Mar 23, 2000 | 05:17 PM
My Scrambler sorry for the weit. Mine just came right off. Try a screwdriver and a hammer that might work. You can still take the axle out if u just take the one side off and the nut and it will slide out and then maybe u could get the housing thing over the nut off.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
