Brakes
Old Aug 10, 2002 | 10:40 AM
Milkman00's Avatar
Hi all.
I recently flipped my Trailboss 325, and broke the master cylinder. I replaced it, and tried to bleed the brakes myself. Fronts bled fine, however, since I am not Inspector Gadget the rears were a little interesting. What I tried to do is pump the brakes, then when I got it fully pumped, I set the parking brake, ran to the back, and bled them that way. It seemed to work, but now It seems like I only have front brakes. Do you think it is because I didn't have someone helping me bleed the backs - or am I doing something wrong???
Also if they bleed correctly, should they automatically go back to the 60/40 combo??
Let me know! [img]i/expressions/face-icon-small-smile.gif[/img]
Thanks
Old Aug 10, 2002 | 12:50 PM
TINKERMAN's Avatar
You can not bleed the rear brakes with the hand leaver.
Must use the foot peddle. There is a serpate resevoir for the rear and it holds very little keep filling as you bleed the brakes.
It is easer with 2 people. todd
Old Aug 10, 2002 | 12:56 PM
RINCON's Avatar
just an idea, you might have bled all the fluid out of the resivoir. i know i did, but i had a lot of air in my lines...... but then agian i don't have a trail boss.
Old Aug 10, 2002 | 10:48 PM
Milkman00's Avatar
Tinkerman:
On the Trailboss - the "Front Brake" is actually a 60% Front / 40% Rear combination braking, so yes, you must bleed the rear brake with the hand lever. The foot lever, has a separate bleeder valve on the rear brakes.
Thanks!
Old Aug 10, 2002 | 11:26 PM
evan's Avatar
You can buy a device that allows you to bleed the brakes by yourself. One of the mechanics I worked with had one. Can't remember the name of it, Sorry not much help. Kind of a little suction pump that you pull the fluid out with and then tighten the bleeder as your doing it.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
