Polaris Sport starter
Old Aug 21, 2002 | 08:13 PM
naed's Avatar
Went through quite a bit of water this weekend with the wife's Sport and now the starter spins but doesn't engage. Any Ideas? Thx..Dean
Old Aug 21, 2002 | 09:20 PM
modquad's Avatar
inside the pull-start side of the motor is a starter bendix. Basically a couple of gears with a spring. Sometimes you can buy time by getting in there and spraying it down with lube. Especially if you haven't normally dropped the drainplug under the pull-start side of the motor. You can remove the bolts from that side of the motor. I use the "broken hockey stick" method, but I don't have an airbox so accessing in from under the seat is easier for me. Basically with all the bolts out, I line up da schtick with a protruding ear on the cover, and give 'er a rap. Once open, you can kinda reach around a get a good look. I do believe you have to pull the flywheel if you want it out...could be wrong, mines been milled for a while...and the starter is out also.
Good Luck,
Ken
Old Aug 21, 2002 | 11:32 PM
Bubba297's Avatar
Exactly right Ken, have to pull the flywheel to get the bendix out.The white lithium spray lube works excellent for drive units like that. I usually clean with a quick drying spray first like carb or brake cleaner. Otta get you going,Bubba
Old Aug 22, 2002 | 07:19 PM
naed's Avatar
Thanks for the information and help..Dean
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
