38 mm carb
Old Mar 21, 2000 | 02:30 AM
sport97's Avatar
i have a 97 sport polaris i was wondering if any 38 mm carb for a atv would work on it because i see good deals on them all the time i have done about everyting else to it but a carb it should have been the first thing i bought i still would like to buy a carb,steering dampner,roller clutch for it then i would be happy thanks for any replies
Old Mar 21, 2000 | 07:56 AM
Mike Chero's Avatar
Sport97,
The 38mm TMX Mikuni should have been one of the first mods you should have made. I wish I'd have done it first too. You'll find with a properly tuned 38, you'll get much quicker throttle response. Of course you'll use more gas too, but not that much more. It all depends how you ride. If you ride fast and agressive you can practically watch gas gauge drop every time you nail the throttle. Mind you, this is the ONLY down side of the 38mm carb.
If your machine isn't ported or have a Weisco piston, the 38mm carb will be of limited use on the top end. The stock ports don't allow enough flow to fully take advantage of the bigger carb.Once you get the new piston and porting done though, watch out! It gets really scary when you nail the throttle.
Old Mar 21, 2000 | 10:39 AM
wolp's Avatar
Hi Mike,
Did the 38MM carb increase your low end at all vs. the stock carb or did it really add to mid and top end while sacrificing some low end.
Old Mar 21, 2000 | 03:48 PM
Mike Chero's Avatar
wolp,
Yes, oddly enough it did. Because of the increased throttle response the low end actually got better. The biggest hit was in the midrange though. Without the porting, my top end didn't seem to suffer, but after 3/4 throttle all the carb did is make extra noise. The stock piston and cylinder wouldn't flow well enough to take advantage of the larger carb.
Old Mar 21, 2000 | 06:33 PM
sport97's Avatar
yes i know that the 38 mm carb well make a big difference but well any 38mm carb work because mostly everybody runs the 38 mm tmx flatside carb on there polaris does it have to be a flatside or well a 38 kehin carb work and thank for your replies early i dont have it ported but have a weisco piston on it thanks
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
