Aftermarket stearing stem
Im gettin ready to purchase a new one and i was woundering who makes the best one for the money. I seen that hotseat makes one and i was wondering if its anygood. Will a set of renthal handle bars fit on my 500 scrambler and still feep the handle bar lights. cause the stock ones set way to high.
My steering has yet to loosen up, but I know it will sooner or later, and when it does, I will be getting the Hot Seat chromoly steering stem and bracket. There is a review of them on this site. Go to the main page and look under product reviews.
As for Renthal handlebars, yes, they will fit. I put a set on my SC400, which has the same light setup as your quad. The lights mount to a seperate bracket that mounts under the handlebar clamp. You will like the new bars, I put the aluminum bars on, and I really like them. Mine are the 400ex bend, I know others who have used the Banshee bend bars. Holding the two sets together, I cannot tell the difference unless I look at the label.
It's basically identical to the stock one except it's made of a chromoly and has reinforements in certain areas for added strength. It's also lighter than the stock unit. The lower steering support bushing replacement is key too.
Chris Picciotto
99 Scrambler 500
Chris Picciotto
99 Scrambler 500
