Scrambler 500 4x4 wheel question
My stepdad has a Scrambler 500 4x4, and wants to put razr's all around. Will putting 20 inch tires on the back and 21 inch in front hurt anything? I figured lowering both would be ok, but never assume.Need input on this please. The stock sizes are 23 inch fronts, 22 inch rears.
yes this will work fine because you are going down the same amout front and back. if it was a 2x4 i don't think it would matter much..
the only thing with dropping 2 inches is you will loose some top end and some ground clearnce.. if it was me i would keep it around stock
maybe try 22 up front and 21s in back?? its all up to you and what you want but make sure to go up or down by the same amount..
i hope this helps
oh and the razors are supose to have some awsome traction but they might wear a little quick on rocks or tar.
good luck.
i hope this helps
good luck.
