rear foot brake, why can't I use it?
I've been wanting to get the spit brake kit. Did you get the additional mater cylinder, did you use the orig? I herd that if you use the one one the quad now, that your rear brakes will feel mushy. Bottom line would you buy them again? Do you recommend them? I'm planing on getting a RCR kit in April, the brake kit this summer, if its worth it. thanks
Bruce L. Hall
99 Sport 400
Bruce L. Hall
99 Sport 400
You should not have any problems using it.
Most of the advice not to use the rear brake refers to the older *non concentric drive* machines where the brake when used with the foot was completely mechanical and quickly went out of adjustment.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
