250 running problems
Old Oct 28, 2002 | 02:36 PM
crpadiem1's Avatar
Default 250 running problems
I have a 1990 trail boss 250 that I have owned for a couple of months. It must have sat for quite a while before I bought it as it took me a while to get going. It ran just fine for about a month but now barely runs at all. It started by not having any power off idle, but it would idle fine. A friend said the carb had dirt in it so I cleaned that, it ran better with no bogging, but still not the power. A few minutes later it started up running rough and bogging intermittently and even backfiring a few times. After going over the carb again no improvement and now it barely runs at all. I am not too familiar with 2 strokjes so any help is appreciated.
Old Oct 28, 2002 | 05:42 PM
2manytoys's Avatar
Did you check the plug,Airfilter,Plug wire,Carb jets?
Old Oct 28, 2002 | 06:06 PM
ftwflh's Avatar
After checking what 2manytoys said then check your compresion it should be over 100psi if not its time to do a topend.
wildbill59
Jun 9, 2015 02:28 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
blaze_master
May 26, 2015 11:18 AM
