Terminal Bard?????
Old Apr 1, 2000 | 11:22 AM
dressel1's Avatar
I am in the process of mounting a winch t my 2000 Xpedition, and in the instructions it mentioned that I should wire the toggle switch to the terminal board. I looked alll over the machine and do not see a "terminal board" can anyone help with the locating of this?????
Thnaking you in advance
Mark
Old Apr 1, 2000 | 11:53 AM
c77dig's Avatar
I put a winch on my explorer and I hooked the wire from the solinode to a hot wire when I key is on. I never found the trrminal board on mine so I just didn't use the toggle swictch and it works fine. Try the brake light wire the one that is hot when I key is turned on.
Old Apr 1, 2000 | 01:01 PM
pairof98s's Avatar
My '98 Sport has the terminal board under the front plastic (just behind the headlight). Mine may be different, but the center plastic piece just snaps off and the wiring is very easily accessible.
Old Apr 1, 2000 | 01:47 PM
Cowman's Avatar
I mounted mine with out toggle switch.just splice into the wires going to the rear brake.Turn on your key and find the hot one with a test light.This way when your quad is running your winch will always be ready to work.
Old Apr 1, 2000 | 07:41 PM
Charlie's Avatar
Polaris has done away with the terminal board on
newer machines. It was nice while it was here but
they must have had too many problems with corrosion in some areas. They did put spare connectors in one year but the next year they were gone. So now I have done like the other posts have
and spliced into the brake switch wire. If Polaris
is looking at this please put spare connectors back into the harness for accessories.
Old Apr 2, 2000 | 01:36 AM
Jaime's Avatar
I didn,t even use the solinoid or the toggle switch i hook it derect to the battery post then to the rotory switch then the winch and i have never had trouble yet it is alot simpler and there is less to go wrong PLUS it is always live key on or of it works for me
Old Apr 4, 2000 | 08:12 AM
dressel1's Avatar
Thanks guys, I wish somebody would notify WARN of the lack of a terminal board. I do appreciate the help, it has saved me a lot of time headaches, and probably beer.
Regards
Mark
Old Apr 4, 2000 | 08:50 AM
cpalmer's Avatar
my 99 scrambler has a terminal board up front under the center plastic nose piece , it has extra connectors also hope this helps
EIF
Apr 20, 2017 07:15 PM
salixair
Nov 3, 2015 08:25 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
mattcraig1
12
Aug 27, 2015 12:23 PM
