HO owners
Old Nov 17, 2002 | 01:00 PM
polarisman3's Avatar
Default HO owners
hey, you HO owners, with winter coming and everying, (i have already posted this once,but no replies) on my machine it has a water in oil light,,,,since it is not hooked up i was just wondering if it was just for the higher machines like the sporsman....is yours hooked up and does yours even have it....i just figured that light would be handy in the winter when u could get condensation in the oil tank....useually what is on the out side of the tank is in the inside...such as frost and such.....
Old Nov 17, 2002 | 08:55 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Default HO owners
I have a 2002 500 HO (also had a 2001) and mine does not have the water in oil light?????????? As long as you ride your machine long enough to get the machine to normal operating temp it should not have a moisture problem. I do not live where the temps are extreemly cold ( rarely ever gets below 10° F) so my machine may have not had the light added?????????????
Old Nov 17, 2002 | 09:20 PM
pest44's Avatar
Default HO owners
My 01 HO has the "water in oil" spot for a light on the indicator panel, but there is no bulb in it.
Old Nov 18, 2002 | 09:10 PM
500DUSE's Avatar
Default HO owners
Mine has it,and it's hooked up.
Never had a problem with water
Always seemed a bit odd to have it.
Old Nov 19, 2002 | 09:07 AM
floodrunner's Avatar
Default HO owners
It’s news to me that this light was ever hooked up from the factory, but apparently it was (is?).
The dry sump design of the 500 engine has always had a cold-weather condensation build-up issue IF you often run the machine only for short periods of time. Short-duration heating, then quick cooling, over and over will, cause water problems within the engine. This problem is more frequently seen in machines used for farm work because they tend to be started and stopped much more often than machines used for recreation.
The “cure” is to always try to run the machine long enough so that it evaporates the inevitable condensation caused by the previous “cool-down” and change the oil more frequently if it’s used for short runs during the winter. The condensation issue is far less a problem with wet sump motors, like the 700.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
