tach conection on S400
Old Nov 18, 2002 | 12:13 PM
dfischer's Avatar
Default tach conection on S400
A search of the archive suggests the sun pro II connected to the yellow/red reverse limiter wire. There are a couple of possible yellow/reds under the front cover and I don't know (and my service manual isn't here yet) which wire that is.
Can anybody help explain where/which that is?
Thanks.
dan
Old Nov 19, 2002 | 05:14 AM
oldenough's Avatar
the wire you want is in a black connector with two black wires on one end and a gray wire and the yellow/r ed wire that you are looking for. I can't remember if the gray wire is in the middle or not, but I
sure you will see the connector I am describing. I hope this helps you.
Jack
Old Nov 19, 2002 | 11:02 AM
dfischer's Avatar
Thanks for your help. My service manual finally arrived and between your advise and the schematic all is well.
Thanks again.
dan
Logan Collins
Sep 5, 2015 08:03 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Charles Gordon
Jun 30, 2015 09:32 AM
tomtcat
Aug 20, 2005 02:02 PM
s205521
Jan 11, 2000 10:04 PM
