SP 500 shift problems
Old Nov 21, 2002 | 09:31 PM
BC5000's Avatar
Default SP 500 shift problems
I put a new drive belt on and for 2 days it shifted just fine. This morning I started it and let it warm up for a while and it starts grinding when I try and put it in gear. I thought maybe the idle was too high, but it still does it even with a low idle. It seems to shift ok with the motor off. I didn't check belt deflection when I put the new one on because I couldn't find a straight edge. If I have to add shims to the driven clutch, is this a big job?
It's just kind of a mystery that it would develop this problem from just sitting overnight.
Old Nov 21, 2002 | 10:43 PM
ftwflh's Avatar
Check your shifter linkages they could have loosened up or may need to be adjusted.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
